Moser 9 inch + 18x11 rims
I know that they say the largest tire you can get on a 2002 Camaro is a 18x10 on the back without having to use the BFH or roll the lip. My question is, seeing how Im going to order it anyway, will the different width on the Moser 9 inch rear end help fit a 18x11 CCW SP550 rim? There are options that allow you to make the width of the rear shorter in 1/2" increments on each side. Wouldnt know if that would help the offset so the rim and tire would fit and not cause any issues. Or am I barking up the wrong tree with the fitment? Car is stock on springs and Koni 4/4 for the shocks.
This picture kind of shows that. 18x10 with 7" backspace for stock length rear, vs 18x10 with 5" backspace with a narrowed rear. The only thing changing is the mounting point of the wheel. The narrowed rear isn't going to open up any more room in your wheel well, to allow for the rim to tuck under more.
