Prostars cracking at every spoke
Old Oct 14, 2009 | 03:14 PM
KevsfastZ's Avatar
Originally Posted by Camaro396
Weld has already seen the pictures.
Thanks.
From other wheels with the same issue?
Kev D
Old Oct 14, 2009 | 03:39 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Maybe wheelczar works for Weld.
I've heard of some of the Weld 5x5's doing that, for heavy cars/trucks.
Old Oct 14, 2009 | 03:58 PM
wheelczar's Avatar
Weld no longer offers a 5x5 bolt circle for that very reason. The applications are more than likely to heavy for the load rating on the wheels. I feel that this defect is due to some abuse put on these wheels from past owners.
Old Oct 14, 2009 | 04:15 PM
KevsfastZ's Avatar
The past owner of these wheels was a friend of mine, had it on a cam only F-body. Its hard to believe that damage from a few years ago would show up now, I guess anything is possible.
Kev D
Old Oct 14, 2009 | 04:25 PM
wheelczar's Avatar
Lets look at the pictures from the front side tomorrow along with the mfg date information. This may give us some insight about the problem.
Old Oct 14, 2009 | 04:47 PM
SJM Manufacturing Inc's Avatar
I'm surprised no one has had any smartass comments referring to never using these wheels and why they went with "X" brand.
Go figure, another wheel breaking, who would have even thought this could happen.
Good to see you noticed the cracks. Good luck!
Old Oct 14, 2009 | 08:34 PM
slow and da curious's Avatar
Glad you caught that before anything serious happened. That could be disasterous if they came apart while flying down the track...even with 1.7 shorts.
I can't see Weld doing anything about them as they were used when you bought them, unfortunately. Hope I'm wrong about that my friend.
Good luck.
You read my mind Steve.
Old Oct 15, 2009 | 12:48 AM
chrysler kid's Avatar
Originally Posted by KevsfastZ
Every single spoke looks like that, on both sides.
Anyone else ever have this issue?
Kev D
How long have you been running without centercaps? the inside of the rim has a loose "spacer" inside the wheel that would allow water to accumulate inside them, and just from the stains where you would put the lugnuts i can tell your wheels have been rusting for a bit
my guess is they sat too long with some salt water in them.
however even with the rust your cracks look more like imperfections in the aluminum than anything. my pro star setup has over 20k miles in daily driving with no issues but i never let them look that dirty
Old Oct 15, 2009 | 02:46 AM
LS1nut377's Avatar
man! mabe go get them welded up? and grind them down? just an idea.
Old Oct 15, 2009 | 07:45 AM
KevsfastZ's Avatar
I didn't have time to go to the shop yesterday, I will have to do it when I get back from Memphis this weekend.
I agree, I'm honestly not upset at all with the situation, just thought it was interesting, I already bought another set for the rears.
Good luck.
I don't expect them to, if this was a extremely expensive wheel I would raise hell. My brothers and friends have been running these wheels on there F-bodies for years, I think I have a better chance of winning lotto before having this happen to me again.
Not trying to be an ******* or rude by any means, but that is just way to far fetched to believe. It's an all aluminum wheel, yes IF the wheel was sitting in the ocean for years it could possibly make sense, but center cap or not, water would get in, and not damage the aluminum to the point of failure.
Would you trust a wheel that was welded and grinded down?
Kev D
Old Oct 15, 2009 | 08:45 AM
wheelczar's Avatar
First of all I would never trust any wheel that had been repaired by welding it back together. Secondly leaving the caps off this wheel does nothing to harm the product at all. In most cases you have to run without caps to drag race. All manufactures have had product fail from one thing or another. This looks like a case of a product reaching its limits.
Old Oct 15, 2009 | 10:24 AM
  #32
Nimitz87's Avatar
just curious where did this salt water come from? he doesn't live close to the beach and AFAIK never driven thru the ocean. (I know the OP)
we don't have salt on our roads obviously down here.
EVEN IF that was the case its an aluminum wheel...not steel.
Chad
Old Oct 15, 2009 | 10:55 PM
  #33
tillery's Avatar
SJM-If anybody would make a crack at whatever wheels he or anyone uses. The mods police would imediataly slam them for what ever they said. Kev-hope you can get fixed up with another set-or something simular-car looks killer on a 5 spoke design.
Old Oct 15, 2009 | 11:27 PM
  #34
So-GT0071's Avatar
Yikes, that is scary. This same thing actually happened to my step mom's C5. It used to have chrome wagon wheels equipped, but about a year ago they all began developing cracks on the spokes. Kind of an odd thing to happen on something that doesn't really weigh a whole lot.
Old Oct 16, 2009 | 03:23 AM
  #35
35th SS's Avatar
I better go check my weld draglites on both cars.
Old Oct 16, 2009 | 08:56 PM
  #36
nitrouspowrdss's Avatar
Actually thats pretty common. I have seen more than one set of Pro Stars do that. I have yet to see that on Draglites or Rodlites though
Old Oct 16, 2009 | 11:29 PM
  #37
cws T/A's Avatar
What is the correct torque?
Old Oct 23, 2009 | 11:32 AM
  #38
DougsfastZ's Avatar
Wheel broke, pics to come.
Old Oct 23, 2009 | 01:09 PM
  #39
KevsfastZ's Avatar
Shitty phone pic, I will get some better ones tonight.
Kev D
