Prostars may be bent? PLZ help
I noticed when i put my prostars on it shakes real bad going 60plus so bad that im scared for my life doin over 100 at the track..
when i jack the car up and let the wheels spin i notice one spins worse than the other. i didnt balance them last time cus the guy said they didnt need it, but worse case if they are bent how much is it to fix it?!
Is there anyway it could be something in my rear end instead?
what do you mean one spins worse than the other? could be a bent axle? could be a bad tire? take and get them balenced. you will be able to see how much runout is in the wheel when its on the balencer and check for a bad tire too. take it somewhere that will take the time to check things and let you see it run on the balencer...
i know its off balance cus the dude told me he didnt need to balance them.. i will take them off and take it to a good shop and that way i can find the problem for sure...
any other suggestions guys?
