I would like to see your Street Drag Setup.
#87
You have to grind your rears if they are not the f-body specific BS wheels. And by grind i mean extremely, not just a little. If you by drag brakes you don't have to do it. They fronts just a little or use a spacer.
#91
Sure, here are some more pics. I am using a UMI adjustable PHB to center the rear, and the fender lips have been rolled:
And here are some pics from before I cut the springs 1 coil and did the rear hose mod. The height and gap almost makes it look like they stick out from the wheel wells, but they don't. With it lowered, it looks flush. I love the way these wheels sit. Also, the Toyo DRs are wide like the M/T's are and it should look more tucked with a narrower tire like the Nitto DR.
#94
#95
ls1 sounds, can you post up pics from the side view? the angle shots at great. btw, have you considered the inserts for those? theres pics of a trans am with them on and i spoke with the guy and he can get them from a shop that he got them made from.
#96
Here are some more pics, sorry if I repost any of them:
I painted my brake calipers black with silver CAMARO decals since taking those pictures too:
#99
1 Post
Ill add with ya on the 17 in steet lites!!
17x9.5s and 17X11s with Nitto 555s, Soon Will have the 555 DRs..275s,315s
Some older ones when I first got them.
BTY LS1sounds..ur the reason I got a set..ur car looked sick they got here just a day after u posted pics of them up..
#100
Awesome and thank you! A local guy also has a set on his black Formula now. For me, these are the perfect wheels. The only other ones I even considered were polished TTII for the retro look, but I am way more happy with these all around.
