Pics of my Bogarts
Old Dec 9, 2003 | 11:03 PM
WicketMike's Avatar
Talking Pics of my Bogarts
Just put my Bogarts on that i bought from Steve (SJM) and here are some pics
click on the link and there towards the bottom.
http://community.webshots.com/album/67370385InNmSX/1
Old Dec 10, 2003 | 12:42 AM
Chris81's Avatar
Looks awesome!
Old Dec 10, 2003 | 01:09 AM
BIGBOS's Avatar
Those look tight, which ones are they?
Old Dec 10, 2003 | 01:26 AM
onyxxtreme's Avatar
arent those the RT's ?
when I get some, Im getting the RR10s for the track
15 or 16x10's and 17x5.5"
and if I ever get rich, another set for the street: LS6 17's
RR10
LS6
Old Dec 10, 2003 | 07:29 AM
Reckless's Avatar
Super Moderator
Me likey!
Old Dec 10, 2003 | 12:31 PM
WicketMike's Avatar
they are the bolted R/T 's
thanks guys!!
Old Dec 10, 2003 | 04:54 PM
SJM Manufacturing Inc's Avatar
thanks guys!!
Looks fantastic.
Pictures speak 1000 words. In my opinion this is a prime example of why there is no comparison appearance wise when considering other manufacture's drag rims. Considering rims are usually what "finishes" off a cars appearance...if this is an important area for you, then Bogart rims should be a first consideration.
For the small amount of additional cost, while being the lightest rims on the market in its class, and being the best show looking rim, in my opinion, Bogarts are the only choice in my book. If I didn't feel so strongly about them, I wouldn't have been working with them creating setups that work with our F-body cars over the years.
In person, these rims look even look better:-).
Old Dec 10, 2003 | 08:17 PM
WicketMike's Avatar
like steve says, in person they do look even better. im very happy these are the rims i chose
Old Dec 10, 2003 | 09:09 PM
MadIceV8's Avatar
Customizing Director
Old Dec 11, 2003 | 02:19 PM
DEEZ98Z's Avatar
Very Nice I got a price qoute on them about two months ago I wish I had that kind of money
Old Dec 11, 2003 | 11:56 PM
White Fire'99's Avatar
sweet, i have those same ones comin my way pretty soon.
what tires are you running and did everything bolt on smoothly?
Old Dec 12, 2003 | 10:54 AM
WicketMike's Avatar
on the rear i have e.t. streets 26x1.5x15 and on the fronts i have the Moroso Ds2's
they bolted up fine except on the front drivers side i had to shave the caliper alittle bit, but the other 3 where fine ,, wierd
Old Dec 12, 2003 | 02:35 PM
Just for some clarifications, the rims are made to be a direct bolt-n-go. Variances come into play due to GM's tolorances. Since the calipers are cast and float, each one is not created equal. This was the case with Mikes one caliper. Other variences which come into play are brake pad and rotor thickness's.
Most people don't do anything to have the rims fit, some have to do a quick clean up with caliper flashing etc on a rotor or two. Do not mis-understand the term "clean-up" as there is NO MAJOR GRINDING ISSUES, usually this can be resolved with a HAND FILE. Our rims are made to have the largest clearance available. If one has to touch a spot up regarding to caliper flashing, most likely it would be worse with any other drag manufactures rims.
Steve
Old Dec 12, 2003 | 04:05 PM
Todd@AZPowerAndSound's Avatar
sweet setup!
