28" tires, v6 springs, and hose mod
has anyone put 28" tires on with v6 springs with hose mod (or similar application)?
I bought micky thompson (ET streets) 295/50 R16 (28") tires and I am going to install the above --so what mods to my wheel well will I have to do? Or did you do?
What wheels are you going to put them on? As long as you have the right offset you should be fine. I am running the same mods you listed and didn't have a problem fitting 28" tall tires
you might need to bang in the fenderwell area, you probably wont need to roll the fenders because the stock wheels dont have an aggressive offset.
im running the v6 springs and the car sits maybe half an inch higher than v8 springs, biggest difference i noticed was that they ride alot nicer. however i havent done the hose mod
