Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
- Camaro and Firebird: Tires General Information and Specs
Step by step instructions for do-it-yourself repairs.
Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
#241
Originally Posted by camaronut502
I have a 2000 t/a with stock ride hight. I would like to run either the nitto 555R 305/35/zr18 or the 315/35/R17 on the back. What are my best choices among the common wheels out their? im just not that sure about rolliing lips and MFH mods, lol. So if thiers a wheel/offset that would work fine please let me know. thanks guys for the info.
Matt
Matt
Common 18's would be Z06 replicas in 18" x 10.5" recommended offset 53 mm.
#242
Originally Posted by 97PredatorTA
So +36 offset will set the wheel closer to the rear quarter panel, and +50 offset will set it closer to the inside wheel well. If I understand that correctly, I think I'm finally starting to figure out this wheel stuff. Thanks for the help.
Now will this offset put it outside the rear quarter? Like sticking out past the fender a little? Because I don't want that either.
#243
Okay, I've read quite a few of these pages...but have another question...So would a 10.5" wheel with a 60mm offset and 7 5/8" BS work on my SS Camaro or would it be too closes to the wheel well? I currently have 11's with I believe the 50mm offset. I have already done all the "messaging" of the inner fender wells and rolled the lip of the fender. Before I buy these I just want to make sure if the 60mm will be too much or not.
From what I understand with a 60mm offset I may need a spacer for these to get the right look (flush with the fender) like my 11's have. What spacers would ya'll recommend and will I need longer studs? If I stay under 1/4" spacer I realize I wont need longer studs. But will 1/4" be enough for the look with a 60mm offset...?
Sorry if this has already been answered before....
#244
#249
The wheels I'm currently looking to buy are available in 5X120 with either 35mm or 42mm offset. I plan on running 18 X 8.5" up front and 18 X 9.5" out back. Which offset do you think would look best on my T/A? I'm thinking the 35mm would look nice, especially with the car being so low. I would think that 7mm of difference would be barely noticeable but I may be wrong. The wheels have a deep dish (2.5" on the front and 3.5" on the rears) if that would make a difference.
#250
In the 8.5" width either offset will be fine. The 9.5" offset for the front will not work with a 35 mm offset, but for the rear would be fine.
#251
Originally Posted by Xsta Z 28
Technically the 5X120 bolt pattern is wrong. The F-Car bolt pattern is 5X120.65mm or 5X4.75"
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#252
Thanks for the reply! I figured that since the HP Evo's that a lot of guys run are 5 X 120, then it should be alright. I will be running the 8.5's up front and 9.5's out back. ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#253
SSU, come over and relax
does anyone know if these will fit:
they are american eagle 211's
size pattern offset bsm cap load
17x9.5 5 on 5 +8 mm 5.50 3151-09 2100 lbs
here is the link for the sizes
#254
HP is supposed to be making the right bolt pattern for F-Cars, just FYI. But you are correct quite a few people run them, but there is a risk involved.
I am curious about that risk. I was thinking of ADR 18x9.5 120mm they talked about using aluminium center rings. But the ADR tech line was worthless...at least the guy on the other end was. More info please.
#255
#256
Ok now its obvious this question has been answered a million times so i hate to ask it BUT im not afraid to considering the money being dropped on wheel/tire combo....Replica ZR1 17x11 50mm w/ 315 Sumitomo HTRZ tires in the back of a 98 Z28 w/ all stock suspension,...question is will it be a fine direct bolt on and drive? or slight possibility of BFH? and ANY chance of rollin my fender lips? And another question on top of that,..if i was to take my car to a body shop and have them roll my fender lips...about how much am i looking at to get that done for my rears? --Thanks in advance
#257
#258
SSU's Drunk Typing Whore
I want these rims but I am not sure if they fit f-body's. They are AZA Z-1's. 18 x 8.5 35mm offset front, 18 x 9.5 40mm offset rears. They also have a 5x120 bolt pattern if that helps. Here is the thread for them - https://ls1tech.com/forums/lsx-parts-sale/355350-gto-rims-aza-z-1-s-18-inch-less-than-2000-miles.html. Thanks.
#259
Originally Posted by Lithium
I want these rims but I am not sure if they fit f-body's. They are AZA Z-1's. 18 x 8.5 35mm offset front, 18 x 9.5 40mm offset rears. They also have a 5x120 bolt pattern if that helps. Here is the thread for them - https://ls1tech.com/forums/showthread.php?t=355350. Thanks.
#260
For the most part it will be bolt and go. The wheels will have to be installed on the car with the axle supported, the axle cannot hang. You may have to do some inner wheel well mods, known as the BHF mod. Rolling the quarters really only applies to lowered cars, as for cost haven't a clue.
Also, since it 17x11 @ 50mm offset works great, is it safe to assume an 18x11 or even 19x11 will also fit great (assuming fender rolling and BFH mods are to be performed) with the 50mm offset?
