front weld prostar
Old Dec 13, 2003 | 07:33 PM
silverTA's Avatar
Default front weld prostar
i got my weld prostar and i grinded the back to make them fit and a little in the front and they still wouldn;t fit in the front
what i can do to make the front fit
Old Dec 13, 2003 | 11:33 PM
WILWAXU's Avatar
No grinding need in the front with a 5/16 spacer.
Old Dec 14, 2003 | 11:54 AM
zdawg28's Avatar
How much of the back did you have to grind, because i've grinded for an hour now, did you have to grind much on the caliper mounting bracket? How about on the wheel itself?
Old Dec 14, 2003 | 12:04 PM
WILWAXU's Avatar
Best method is to use a marker and trial fit the wheel and only grind where needed.
Old Dec 14, 2003 | 01:06 PM
SPANKY LS1's Avatar
DO NOT GRIND THE BACK OF THE WHEEL! Grind the caliper only..."Tom the Roofer" has pics of his front calipers that were ground down that he emailed me when I was doing mine, might wanna hit him up, see if he still has the pics. Not that much grinding is required, mainly taking the "squareness" of the caliper and making it "rounded". The tires stick out with a spacer, it looks 100X better without, IMO.
Shawn
Old Dec 14, 2003 | 07:08 PM
silverTA's Avatar
i did use a spacer for the front and i grind alot in the front and still wouldn't fit
i grind alot for the the back and also i grind caliper mounting bracket(i think alittle more for the back and they will fit)
Old Dec 14, 2003 | 07:22 PM
WILWAXU's Avatar
What size rims? What size spacer?
Something doesn't added up...
Old Dec 14, 2003 | 07:28 PM
silverTA's Avatar
15x4 (i got the spacer from vents here i don't know whats the size)
