Will 18's fit on my t/a?
This might be a noob question, but I was wondering if 18's will fit on my 2001 Firehawk. When it comes time for new tires I was thinking of getting some TT2's, but I like the 18in ones as opposed to the 17's.
Sure will. A lot of people run 19s too. You could run 20s too if you want to look . The key is running a tire with a lower sidewall so you end up with the same diameter i.e. a 275/40R17 that comes on most of our cars is roughly the same diameter as a 275/35/18. There is a calculator on tirerack and some of the other tire websites that have calculators...probably in a sticky above too.
