Experience with C5 wheels/tires on Fbod?
Old Jan 9, 2010 | 11:20 PM
nj02vette's Avatar
Default Experience with C5 wheels/tires on Fbod?
Just installed my stock C5 thinspoke wheels with stock C5 sized tires on the TA.
For reference, the wheels are:
17x8.5 in front, 58mm offset(?), 245/45R17
18x9.5 in rear, 65mm offset(?), 275/40R18
It seems like in heavy cornering (where there would be body roll), I'm hearing some noises like tire rub? Turning slowly lock-to-lock there is no issue (like pulling into a parking spot).
Car is not lowered and rear seems centered. Noise is definately on one side when turning one way, and switches when turning the other way.
Anyone else have experienced something like this? I can't imagine they are rubbing on the outside fender, they seem so inset, must be rubbing on the inside.
Opinions? Front or rear rub? What do I do to take care of this? Spacers?
Help would be appreciated plus any recommendations.
Old Jan 11, 2010 | 11:02 AM
nj02vette's Avatar
Someone has to have some comments.
How about grinding down bumpstops?
At least chime in and tell me how bad the Eagles crumbled to the stinkin cowgirls.
Old Jan 11, 2010 | 04:19 PM
Xsta Z 28's Avatar
REAR tire is hitting the inner wheel well. Need to do the BFH mod or get some spacers on the rear wheels.
BFH = Big F'ing Hammer . . . take the wheel and tire off, and you should see clearly where the tire has contacted the rubberised undercoat in the wheel well . . .massage away, and re-undercoat . . . there are pic's out there some where . . .
Old Jan 11, 2010 | 04:22 PM
chaman's Avatar
Thats the problem with Vette wheels. Get the smallest possible spacer. I would consider the bumpstops only as a last option...
Old Jan 13, 2010 | 09:23 AM
b-ron's Avatar
anyone with pic's
Old Jun 11, 2010 | 05:18 PM
redtransam95's Avatar
what size spacer usually works?
Old Jun 12, 2010 | 11:03 AM
ChrisRZ28's Avatar
I have a lowered Z28 with 17x9 1/2 & 11 ZR1s. I used to get rubbing in the rear until I changed my panhard bar, LCAs and added a 1/4" spacer. I've got a 1/2" spacer on the front (not for rubbing issues) but the tire rubs on numerous spots on the fender liner. The fender liner is fairly flexable so no big deal there. Just inspect carefully. If you end up getting spacers you will need longer wheel studs and new lug nuts. Good luck.
Old Jun 12, 2010 | 12:39 PM
themadspoon's Avatar
I have C5's on my car with a 285/35/18 and the fit with no rubbing after rolling the quarters.
Old Jun 14, 2010 | 10:48 PM
Egg1456's Avatar
used to have the y2ks had to beat the hell outta inner fenders sell them if u can, get some from oe wheels with the correct backspacing
Old Jun 15, 2010 | 03:48 AM
9WhiteCamaro9's Avatar
i got the ones from OE and i havent had a prob with em yet and they never rubbed anything
