drag wheels and baer brakes
will prostars fit over 2 piece eradispeed rotors and c5 zo6 calipers on a 00 TA or do I need to find something different? Im not sure if there is a difference in size over the stock rotor. Thanks
are they c5 rotors or f-body rotors? you can run c5 calipers with either
i don't know much about drag wheels or brakes but chances are it won't work. if they're c5 rotors you'll need at least a 17" wheel and some drag wheels require grinding of stock calipers on stock sized rotors.
