18X10.5 z06 wheels 285/35/18 tires will it need a BFH mod?
youll prolly have to jack up the rear end after the car is jacked up on the frame, to allow the tire to fit youll see what i mean when you do it, the tire will look like its rubbing, just jack up the rear end and it will all fall into place.
ps i did a alignment on my car its lowerd as well my centerline was way out to the right i belive which is why i was getting rubbing on my left side inner fenderewell i was thinking about getting a adjustible panhard and seeing if i can bring it back to center.
oh and you may think about taking your bump stops out "you may need to cut this" but if you jack your car up on like a 2 post lift the wheels sit on the bump stops thats a 10.5 wide wheel tho no problems driving i guess if you got air borne you might gouge the inner lip of your wheel lol..
i had to bfh in a very smaller area to get them to fit in my car. what i did was drove around for a few miles to see where it was rubbing then removed the wheels and hit the 2"x2" section that was rubbing. since then i have order new studs and some spacers so i have no rubbing issues at all with a 315 dr.
