people with 325/50/15's and lowering springs got pics?
Heres a couple of my WS6. Coil overs up front dropped about two inches, rear is stock with 1/2 coil cut and isolators removed. Rear is narrowed a total of 4.5"(2.25 per side), wheels are 10.25 with a 5.5BS so the tire actually sits in the stock location.
The Bogart GT's look sweet. I plan on ordering some bolted GT's to go with the narrowed rear from Midwest. Narrowed 3" per side and a 5 inch backspace. Should look pretty sweet. Just have to wait for the tax refund...
It's been less than 12 hrs, be patient.
It's not exactly what you're looking for, but I run those tires with stock rear springs and no spring isolators (~3/4" drop). For me it took lots of BFH work, rolling the outer fender lips, adj panhard, adj LCA's to get them to fit. I had pro-kit springs on there originally but it was way too low and rubbed the outer fenders bad. Hope that helps.
Car looks awesome Philip as always! I'm still trying to get my 325's to fit! I better hurry and finish mine for pinks!
#34
edit: btw my car should be sitting identical to NOSJNKY's I got measurements/questions from him I have a stock length 9" rear however. qa1's up front 1 full coil cut springs in back 9" raises the rear vs the stock narrowed 10 bolt.
Chad
#36
