whats the widest tire i can put on stock 02 ws6 wheels
you really need to search. this has been covered hundreds of times.
talking about putting 315's on stock wheels can result in thread lock or deletion. do not do it. nittos run really thin but that's still frowned upon. do 285's if you MUST go wider than stock. that's what i have. otherwise look into new wheels or get yours widened.
sumitomos also run narrow...i have had 315s on my 9.5 for over 2 years...i have posted a ton of pics on this site and nobody has once mentioned anything about bulging...so obviously it doesnt look like **** with all tires...
original poster, if you want wider tires just do 285's. i see no point in buying a 315 that's no wider than most 295's just so you can say you have 315's.
also, you may want to do a search on sumi htrz's before purchasing, i will not comment as i have never owned them, but there's a reason i never will.
im sorry but that looks like tit dirt to me... not very good angles of the rim and tire, im sure you just dug these pics out of your comp but i can tell they are bulging and they dont look right... do you know that if you put a 315 on a 9in wheel your still only gettin 9" worth of traction, so all your doing is wasting your money, not that 315's are a lot more but still, not to mention it calls for MORE weight when the tire does not fit the wheel properly so you might feel vibrations (not that it will out vibrate your lt1 driveshaft lol (friends lt1 driveshaft sucks) unless you got yours replaced) but still... iunno just my opinion looks like a terd and i would never do it, im sorry if it feels like im bashing you im not im just expressing my opinion and your car is the example... cause if you look at the pic from the back and look at the inside it bulges a lot more on the insdie the the outter... iunno maybe it's just me, i work at a tire shop and see this **** almost everyday... i wouldnt recommend it and the stickies back my up here... just get the recommended size tire or by wider wheels...
Heres my thread about my WIDENED WS.6 wheels, with Nitto 555s in 315/35-17s https://ls1tech.com/forums/wheels-ti...pics-here.html
Looks stock from the side:
![](http://i252.photobucket.com/albums/hh18/Two_6s/SOM/img_0658.jpg)
Nice and fat outback!
![](http://i252.photobucket.com/albums/hh18/Two_6s/SOM/IMG_1414.jpg)
