Tires rubbing on bumb stops
Old Feb 7, 2010 | 06:36 PM
94BlueZ28's Avatar
Angry Tires rubbing on bumb stops
I have some 315's on my 17X11's ZR1's and just noticed that upon install once again that the rim and tire are rubbing up against the bumstops brackets. My bumb stops are removed because the rubber was seperating from the actual bracket and now I noticed that the actual nut plate area where the bumb stops mount is touching, although my rear suspension is just hanging fully in the air on some jack stands, Would putting it back on the ground eliminate my problem? I might take that chance of hitting the brackets if I launch hard or something possible, right? Would it be dumb to cut these off? I'm getting some 15X10 race stars here shortly and will be running 325/50R15's. So I would imagine that these tires will be rubbing as well. Should I just heat it up with a torch and then beat them in some or cut them off. Anyone else have this problem and if so what did you all do?
Old Feb 7, 2010 | 07:45 PM
tals7's Avatar
Smile
you need to cut the brackets off.also the 325,s will hit.to remove them u could use a cut off wheel and or air saw.with the 325 mt dr and a 15/10 rim with 7.5 bs you will also have to make room in the front inner wheel house near lower control arm but they do fit.i have run them for awhile now.i have pics if you want to see them on car.
Old Feb 7, 2010 | 09:33 PM
94BlueZ28's Avatar
Please let's see pics! I beat the hell out of the front already so I think I may be good except for the bumb stop ****!
