Too Much Rubber???
Old May 11, 2010 | 08:25 AM
01ssreda4's Avatar
315 tire is too much rubber for a 9 inch wide rim. With an 11 inch wide rim you're good.
Old May 11, 2010 | 08:33 AM
Squirts11's Avatar
Originally Posted by cts-vdriver
I recently have been told that i should not put 315/35/17 tires on my car. The reason being that its too much rubber and it will create too much friction.
Lol...This is like saying you shouldn't ever fill up with gas, as it will weigh the car down...
Old May 11, 2010 | 09:16 AM
BRD-PREY's Avatar
Thunderstruck any idea how the 335/30 18 would fit?
Old May 11, 2010 | 10:54 AM
BobDoLe's Avatar
he was talking about rolling resistance. imo, your car could use the extra rubber if you like the look and NEED the traction. on these cars, its welcome. on a civic, maybe its too much.
Originally Posted by therealcreeper
there is such thing as too much rubber, if we are talking about drag racing. if you can dead hook on a 245, then a 315 will slow you down. it creates rolling resistance. also, it is rotating mass. and unsprung weight. all bad. there's a reason people run skinnies up front.
really, it won't make a huge difference unless you're trying to squeeze every 100th out of it, but there is truth to it.
^^^ could not have said it better.
http://www.tirerack.com/tires/tirete....jsp?techid=29
Old Jul 28, 2010 | 11:44 PM
6spdchevy's Avatar
From: Oklahoma City, OK/North Long Beach/Paramount, CA
Originally Posted by 1999Z28
What size tires do you run on the 18x10.5s. I was thinking about either running a 315/30/18 all the way around or 295/35/18. Will a 315 fit ok up front?
iirc i believe this setup he is 18x10.5" machined face/black vent C5 deep dishes w/ 275/35 Cooper Zeon 2XS's up front, and Nitto NT555R 335/30's out back.
i've seen others with 295/35 all 4 corners on 18x10.5 C5 DD
also 275/35 front & 295/35 rear or 295/35 front & 315/35 rear
but from what ive read & researched u need BFH & PHB
Old Jul 29, 2010 | 03:12 PM
AZ2ENVY's Avatar
Dude .... pics of the 1st gen in your avatar please !!! Im running 18x10.5 all around as well on a lowered car .
