1993 Camaro Jegs set up?
Old Mar 16, 2010 | 12:55 AM
Flores96TA's Avatar
Default 1993 Camaro Jegs set up?
Diameter & Width: 15 x 10"
Bolts & Bolt Circle: ???
Back Spacing: 6.50"
555-67038
$134 for these ones. Any good? I have looked around and they look great. Any problems with the wheels?Want about 275 out back.
Old Mar 16, 2010 | 01:10 AM
Flores96TA's Avatar
stock rear: yes
15x8 w/5.5bs: what i need
thanks for info/pm's
anyone else
Old Mar 16, 2010 | 09:29 AM
Camaro396's Avatar
There's not really any point in going to a 15" rim if you're going to run a Jegs or Summit wheel, as they are about as heavy as your stock wheels, being a china made steel wheel.
Old Mar 16, 2010 | 06:28 PM
Nsty98LS1's Avatar
from my experiences with the summit & jegs wheels, they are definitely lighter than stock wheels. especially my 17inch Speedlines. a friend runs them on his mustang & when we swap his tires at the track, his welds are only a few lbs lighter. as for being steel, you're wrong on that, they are most definitely aluminum.
to the OP, on a camaro with stock width rear a 15x10 with 6.5 bs is gonna hang out of the wheel well. a 15x10 with 7.5 bs is what you need & both Jegs & Summit do not have that backspacing available. a 15x8 with 5.5 bs will work & many people on here have 275s on a 8 inch wide wheel.
Old Mar 16, 2010 | 07:35 PM
Camaro396's Avatar
I said steel as sarcasm as to how heavy they are, I know they are a cast-aluminum wheel. A 15x10 Summit Star was 8lbs heavier than a 15x10 Weld Prostar when weighed at our shop. That's quite a bit of static weight difference, let alone rolling mass.
Old Mar 16, 2010 | 07:49 PM
big block camaro's Avatar
my 15 inch jegs front rims are 1 1/2 pounds lighter then my draglites and look 10 times better
Old Mar 16, 2010 | 07:52 PM
my question is how these guys with stock width rear ends and 15x10 71/2 inch backspace rims are gettin 325/50 15 in stock wheel wells i had to cut my inner frame and plate it to eliminate those ribs in there
Old Mar 16, 2010 | 08:09 PM
Camaro396's Avatar
You must have a custom one off set
I didn't do **** but bolt my 325s on. No cutting or grinding. Tapped a bit with a BFH on the inner wheel well, that was it.
Old Mar 16, 2010 | 08:10 PM
did you tap where the rubber stopper goes mine were hitting not into the whole beat my car with the hammer lol
Old Mar 16, 2010 | 09:51 PM
Flores96TA's Avatar
So Weight is the main thing? Dont get me wrong if I still had the cash rolling in I would buy a set of welds but on a tight 2 kids and a wife budget>
Old Mar 17, 2010 | 09:19 PM
DYING BREED's Avatar
they are fine, but for serious track use, no. they use acorn style lug nuts, not the shank style like the welds, which with aftermarket studs, make a strong combo. the jegs wheels are good for street use and should take more abuse than a weld, considering they are listed as a racing wheel, the jegs are for street... just my .02
