Will these tires fit?
Old Jan 3, 2004 | 07:53 AM
DopeFedZ's Avatar
Smile Will these tires fit?
Does anyone know if 295/30/19's or 315/25/19's will fit on the rear of a 98 Camaro?
Old Jan 4, 2004 | 01:20 PM
DopeFedZ's Avatar
anyone?ttt
Old Jan 4, 2004 | 05:58 PM
NBM2001z28's Avatar
Restricted User
looks like you get to be a guinne pig
Old Jan 4, 2004 | 09:52 PM
OctaneZ28's Avatar
Kinda depends on the wheel you're mounting these tires on.
295/30-19 with a 19x10 wheel (25.97" height) or 315/25-19 on a 19x11 wheel (25.20" height) I believe would fit with the possible need for hammering in the inner wheel well and rolling the fenders.
The 295 would have a better chance of fitting better for obvious reasons, and I think it would look a little better considering it's extra height. Either one is going to have very little sidewall.
Old Jan 5, 2004 | 10:56 AM
DopeFedZ's Avatar
thanks guys I guess I will stick with the 295's for the rear and 275's up front.
Old Jan 8, 2004 | 08:58 PM
DopeFedZ's Avatar
before I make the purchase anyone else have some helpful advice or opinions?
Old Jan 9, 2004 | 10:07 AM
JonSS's Avatar
I ran 19's on all four corners, and ran 275/30/19's on all four corners. So I can tell you from experience that the fronts will fit just fine. I would think you'd be okay with the 295's in the rear as well. Might need to roll the fenders, but maybe not.
Old Jan 10, 2004 | 09:18 PM
Eugenio_SS's Avatar
provided you have a 11" with proper offset, the 315s will fit.
I have it in 17s... it'll basically be the same, except you have more your wheel is bigger and less sidewall... but overall, the whole wheel/tire combo will bw the same sizes... so you should not have many issues.
Old Jan 12, 2004 | 03:23 PM
QUIK WS6's Avatar
I fit the 315 nittos out back on my 99 Ta with stock rims and no hammering cutting or anything. And the best part they don't rub.
