What backspacing for billet specialities?
Old 03-29-2010, 06:54 PM
99Ws6TransAm's Avatar
Default What backspacing for billet specialities?
Gonna be ordering a set here from a local guy i know. Hes looking for specs and such. I know they make um f-body specific..but is that just the rears? So the proper wheel for the rear would be
15x10 7.5 backspace.
What are the proper specs for the front runners? 15x4 by what?
Old 03-29-2010, 07:18 PM
blackls1ta00's Avatar
1.75 bs im looking into a set also
Old 03-29-2010, 07:32 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Most guys, myself included, are running 15x4s with 1.625 backspacing
Old 03-29-2010, 09:14 PM
2FNQUIK's Avatar
If you guys are serious about ordering a set shoot me a pm and I'll put you in touch with someone who I am more than sure can get what you need
Old 03-29-2010, 10:54 PM
can you run no spacers with those back spaces? I researched a bit and came up with a 2.25 front backspace. So i wouldnt need spacers.
Old 03-30-2010, 06:22 AM
1BADTALS1's Avatar
no spacers. just have to grind the edge of the caliper.. took me less than a min. per side.
Old 03-30-2010, 12:26 PM
Z28/2002's Avatar
I had already clearanced my front calipers for Draglites so my Billet Specialties fronts fit with no spacer. If you get the FBody specific rears then they fit with no grinding or spacers.
Then again 1BADTALS1 took just a little off and his fronts fit
Old 03-30-2010, 02:03 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,174 Likes on 763 Posts
Grinding of fronts is minimal check out this short article:
http://www.planetlsx.com/tech/Grindi...reet_Lites/122
