Help,im cleaning my zr1's
well i started around 8 something and ended right AT 1PM , YEAH i didnt get nowhere except a hurt back and fingers hurting as hell. I used 2000 grit paper to wet sand them and mothers power ball with mothers mag aluminum polish. they look the same as they did before , sucks that i spent so long cleaning them. Now im going to paint them black or sale them and buy new rims , this pissed me off
edit maybe cause I didnt wax them?...
man...that's to bad....can anyone chime in and tell me if the polished ZR1's are clear coated?
If you're using a metal polish and the polish does not turn black almost immediately (within say 20 seconds), you are not polishing aluminum. Aluminum polish is too aggressive for wheel clearcoat, and you're probably just scratching it up. Try a plastic polish -- Mothers or Meguiar's should do -- see how that goes. You can use a PowerCone if you want to save some time.
I used mothers with mother power ball yes it turned black super fast and my hands r still cramping up that's how hard I was wet sanding , I'm going to paint these hoes black , its too hard keeping polish wheels clean
same as mine...I only did one wheel and takes a long time.
Might want to just do one every weekend.
Good luck
You can see how mine came out next time we see each other.
I used Clear coat remover then 2000....I'll have to check on that.
Good luck
