psi question
lol The whole Firestone tire debacle. The placard stated 26 psi! On a 4,000 lb vehicle! No wonder the tires blew out and caused roll overs. Everyone is entitled to their opinions, absolutely. But I dont understand why you would ignore what the vehicle and tire manufacturers/engineers have studied, tested and concluded is best for your vehicle? As stated before, follow the placard or owners manual. The owners manual does state increasing the pressures for high speed driving, BUT NOT TO MAX.
The tire pressure on the sidewall is the "limit" not the standard inflation pressure, because that may vary from car to car. Go with what it says in the owner's manual or the door placard. That's what the car was designed to run with.
The tire may also be rated for 150 MPH, but that doesn't mean you should always drive 150 MPH - only that it's the maximum the tire is rated to withstand under normal conditions.
Sorry for the long post, but I feel better now. Best wishes.
Also, like I already said, opinions are one thing, but this is a situation where there is a right way and wrong way to do something. The gray area is very thin...and running MAX psi is not in said area.
Simple science (which you seem to have a good grasp on) is how the manufacturers come up with the recommended psi's. This science goes against running at the high of a psi...that is unless you car is in perpetual motion at 150mph and you just hop in and out when you need to go somewhere.
Do car-savvy people everywhere a favor and trade in your camaro for a jetta, put on "rims" and tires with a thin sidewall so you have a reason to run 51psi, and throw out your camber like a VIP. (I bet you think you'll have even tread wear then, too!)
Did I mention you're still doing it wrong?
To the other guy....are you saying im rice and have a mullet because I have my tires at the max psi? Whats the logic behind that one?
If you have a bolt that can withstand 500 lb-ft and the torque spec for the part is 100 lb-ft, what do you torque the bolt to?
If you are at the maximum inflation pressure of the tire, you are within the spec of the tire, but you are out of spec for that particular installation on the car. Run what you want to run, but do so knowing the potential risks. Just as many people run 315 tires on 9.5" wide wheels and say it's fine, their "opinion" is outside the manufacturer's design specification and just because they haven't had a catastrophic failure yet doesn't mean it's safe.
