ar rebel question need wheel guro
well i got a set of rebels basiclly given to me only problem is they are 17x9 5x4.5 instead of 4.75 they have a 24+ offset and 5.94 backspacing these are really nice wheels and id like to use them is there any way to use these?
will a 4.75 to 4.5 adapter work and be ok clearance wise?
if there is no way at all to use them i guess ill have to sell them to a mustang guy
Wont work. +24 off set will already push you tires inline with or slightly past the fenders. you will more than likely cut tires on the fenders unless you car is really high. lol If you get an adapter you will push the rim out farther. if the rims were approx. +50mm offset or higher it may have worked
