fitting 18x 10.5 wheels on a 4 cornners?
Old May 27, 2010 | 05:41 PM
BillS's Avatar
Default fitting 18x 10.5 wheels on a 4 cornners?
I am looking to move up to a 18 in wheel to use less expensive slicks for autox. The question is will a 18x10.5 rim with 56mm offset and 7.95 in backspace fit in the front? I have allready used a hammer and such to male clearance in the rear for the 17x11 rims I use now, but in the front I have 17x11' with a 36 mm off set so they slide right on no mods.
Old May 27, 2010 | 05:56 PM
KILLA-BLACK-Z28's Avatar
That is the exact size and offset I run on all 4 Corners, no modifications to fit.
Old May 28, 2010 | 02:40 AM
unknown pontiac's Avatar
What size tires do you run killa black z28, Front and back. I am looking to run the same thing.
Old May 28, 2010 | 11:09 AM
295/35's all 4
Old Jun 15, 2010 | 03:22 PM
BillS's Avatar
Ok got the rims I will need a spacr for them to clear the spindle. I have the cheap Mr gasket spacers and they fit in the front with those, but I was looking for a Hubcentric spacer that I could use. Anyone know a source for those for the camaro.
