19/20 rim combo- Tire Nightmares! HELP!
Ok, I ordered a set of OZ Ultralagerra's for my 2005 Z51 Corvette. I ordered a front 19x8.5 and a rear 20x12. My problem is Im going to run a 345/25/20 out back and don't know what to run up front. I'd like to go with a 265/30/19 but the lowest "approved" size by nitto is a 9.0" rim. I'm gonna run Nitto Invo's. If I go with a 255/35/19 up front this will have only a .76+ diameter and may st off the active handling.
Has anyone fit a 265/30/19 on a 8.5" wheel? pros/cons?
ANY AND ALL INPUT IS APPRECIATED. THANKS!
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Good to hear. My other concern is setting off the active handling in the vetttes comp. I wonder if the 265/345 combo will be ok. I've compared these two on a tire calculator and it seems this is the perfect combo with the overall diameter diff only being 1.53" which is optimum considering you want at least a 1" diameter diff between the front and rear. Am I seeing this correctly?
265, and 275 both should be good.
