skinnys prostars
Old Jul 12, 2010 | 07:47 PM
Marz's Avatar
Default skinnys prostars
broke my stock wheel studs using these rims.. so what length are you guys running to put them all the way out past the rim stock ones are 2 inch so just need some input thanx!
Old Jul 12, 2010 | 07:58 PM
Marz's Avatar
the longest I can find it 3 1/4...hope that will do....
Old Jul 12, 2010 | 08:01 PM
Tommyv8's Avatar
The stock studs are 1.5" and weak. I have 2.5" ARP studs on the front, which still won't pass NHRA tech as the stud doesn't pass into the head of the lug (especially since I'm running a 5/16" spacer). Still a ton better than the stockers, and they'll probably be ok. I do want to grind the front calipers to eliminate the spacer and therefore get 5/16" more thread engagement.
If you want to do it right the first time then get those 3.25" ARP studs, which admittedly cost twice as much as the 2.5" studs and look goofy with the stock wheels (if you're still using stock wheels sometimes) but will pass NHRA tech and will give extra peace of mind. I'm definitely going to get the 3.25"s for the rear.
Has anybody here ever broken a 2.5" ARP wheel stud? Just curious.
Old Jul 12, 2010 | 08:10 PM
Marz's Avatar
ya i will get the 3 .25 cause i already got the open lug nuts with the cap ... thanx
Old Jul 13, 2010 | 02:36 PM
johnzss's Avatar
are you guys are running 3.25 all the way around with the drag set up?
