will there be much difference?
Old Aug 19, 2010 | 12:49 PM
Madellous's Avatar
Default will there be much difference?
will there be much difference in performance going from a 9 inch rim with a 275 tire to a 8.5 rim with 255 tire? rim size will be from a 17 to 19. thanks
Old Aug 19, 2010 | 06:07 PM
Madellous's Avatar
bumptastic
Old Aug 19, 2010 | 06:10 PM
Tyler_LS1's Avatar
The 19" wheel is most likely heavier
Old Aug 19, 2010 | 06:14 PM
edwardzracing's Avatar
Absolutely there will be a difference... you're adding rotational weight by going to a larger wheel. I'll bet good money the first combination was lighter than the second... even if you are going to a slightly smaller width tire. You'll know right away if it's a difference you can feel from the seat of your pants or not.
Old Aug 19, 2010 | 06:27 PM
Madellous's Avatar
i can deal with the slight increase in weight, what about traction though?
