What psi to run in MT Et Street Radial?
Old 08-22-2010, 09:36 PM
10 Second Fun Car
jlrz28's Avatar
Default What psi to run in MT Et Street Radial?
What pressure do you guys run on your drag radials? Ive been around 18-20psi and they have been hooking quite well. Just wanted to get other opinions, thanks! This is on the 255 50 16 size.
Jason
Old 08-22-2010, 10:05 PM
Dragman's Avatar
I run 18 lbs on NOS and 20 to 22 lbs on motor. 295x45x17 M/T DRs
Old 08-22-2010, 10:31 PM
10 Second Fun Car
jlrz28's Avatar
I'm guessing these are the newest ET Street Radial IIs?
Old 08-22-2010, 11:15 PM
TTA850's Avatar
255/50R16 and I set them to around 18psi cool (before my first pass) which usually gets me around 20psi hot (after a run), sometimes they check a little higher and I reset them back to 20psi. I've only got 15 passes on this current setup but seems to be working with a best 60ft 1.651 and worst was 1.674
HTH,
Steve
