Lets seem em! Narrowed rearends with Street/Strip setup
I would like to see some narrowed rears with street/strip setups. I found a few searching around, but would like to see some more. I also found some on SJM's website and so far like the Floyd's, D6, D10, and D12.
Also, thoughts and opinions are helpful.
Thanks,
Thanks,
1 Post
Reasons were Looks and I drive it, and tire choices was a lot of it. I didnt want something soo skinny I had to settle with the ugly M&H tire. I went with a 205/50/17 BFG KDW2 because they look bad *** and are a great tire.
![](http://i963.photobucket.com/albums/ae114/JDMyers88/The%20Firehawk/GetAttachmentaspx13.jpg)
![](http://i963.photobucket.com/albums/ae114/JDMyers88/The%20Firehawk/Wheels/DSCN0595.jpg)
1 Post
Thanks buddy!!
Narrowed 12 Bolt 2.5in each side, 5 total. The rear is factory springs with the hose mod, (took out the isolator) Front is QA1 Coil Overs.
Front and rear are drag shocks and I drive it as much as I can, If its not raining and Im not working, you bet I get it out. Drives great, not as bad as people made drag shocks to be. Its a lot of fun!
![](http://i73.photobucket.com/albums/i203/GMMillwright/CopyofIMG_2471.jpg)
![](http://i73.photobucket.com/albums/i203/GMMillwright/IMG_2473.jpg)
![](http://i73.photobucket.com/albums/i203/GMMillwright/IMG_2478.jpg)
Bogart bolted GTs (street/strip series). 15X4 and 15X10 (5" backspace). Rear narrowed 3" per side. Heater hose mod, BFH, trimmed bump stops, cut factory springs 1 1/4 coil. M&H radials all around. 185/75 and 325/50.
