295/50/r16
Old Sep 2, 2010 | 02:49 PM
gapp94vert's Avatar
Default 295/50/r16
will a 295/50/r16 tire fit on the rear of my 98 trans am? im sure ill have to roll the fender, but other then that is there anything else i would need to do thanks for the info.
Old Sep 2, 2010 | 03:55 PM
whyte95ZRida's Avatar
What wheel are you running?
Old Sep 2, 2010 | 04:16 PM
gapp94vert's Avatar
16inch weld prostars
Old Sep 2, 2010 | 04:40 PM
someday's Avatar
but what width? should be on a 9" to 10"... also, its 27.6" tall, (2" taller than stock) so it will throw off ur speedo/ABS/gear ratio...
Old Sep 2, 2010 | 05:05 PM
gapp94vert's Avatar
thay are 16x8, in the mickey thompson book it says that the new drag radial size 295/50/r16 approved rim width is 8-10 inch. yea my speedo and gears are setup in the comp. for 275/55/16 being i have mh racemasters on there now.
Old Sep 2, 2010 | 09:27 PM
223HAWK's Avatar
I would think they would fit..I have a 28in tire 325/50/15 and its tight but A LOT bigger than the 295s. If anything youll have to do a little hammering to the wheel wells..
Old Sep 2, 2010 | 10:02 PM
Mr.z/28's Avatar
If they are 16x8 weld prostars the 295/50/16 will fit. youll need to do a lil hammering thats about it not too much. I ran BF Goodrichs radials TA on my stock 16x8 z28 wheels. I didnt know I was loosing alot of gear. I have 2.73 gears and when I mounted those on without me knowing till I found out later I had 2.34 gears lol but yea long story short, they will fit.
Old Sep 3, 2010 | 09:22 PM
gapp94vert's Avatar
awesome thanks everyone for the info. so yous are saying i will have hammer the inside of the fenderwell? or are we talking about the fender lip?
Old Sep 4, 2010 | 05:56 PM
Mr.z/28's Avatar
Inside the fenders... youll see. if you have them already mounted on the rim, mount both of them on and run it a bit, example around the block so that they can rub on something and then youll be able to see where to hammer it in.
Old Sep 4, 2010 | 05:58 PM
Mr.z/28's Avatar
Ill try to find a pic or take a pic of where I hammered on my car, although Im not running them anymore... the BFH is still there....
Old Sep 5, 2010 | 06:41 PM
gapp94vert's Avatar
cool thanks for the info mr z28. yeah if you have pics that would help alot. also do you have any pics with that size tire on the car? i would like to see what they look like before i mount them on the car. if anyone else has pics post them up thanks again everyone for the info.
Old Sep 5, 2010 | 10:51 PM
Mr.z/28's Avatar
Pics I do have.. go to my profile on my car album. youll see em there.
since you have a TA isnt the rear fenders wider than camaros???
either way Imma have to take some pics to show you man.
Old Sep 7, 2010 | 06:36 PM
gapp94vert's Avatar
dam car looks good mr z28. me likey lol. yea if you got pics of where you hammered in the fenderwell that would help out alot. thanks again.
Old Sep 7, 2010 | 08:04 PM
Mr.z/28's Avatar
Yea man no prop. and thanks..
Hopefully tomorrow if its not cloudy. I hope I wont need to remove the wheel to show you.
Old Sep 7, 2010 | 08:19 PM
gapp94vert's Avatar
if you do you dont have to worry about it. ill figure it out . a little drive around the block will tell me lol.
Old Sep 7, 2010 | 09:38 PM
Mr.z/28's Avatar
Hey Man. I found a pic.
The baby blue would be the areas where you would have to BFH.
That was the only area I BFH on mine.
You can also try adding a 1/4 spacer for more clearance. =]
I had em, no proplem here.
Old Sep 7, 2010 | 09:39 PM
Mr.z/28's Avatar
The night I first mounted my 295s the ride home they were rubbing.
next morning took them off saw where it was rubbing, Hammered it in =]
mount them on, ride around the block like two times and start hammering.
