will these 17x9 fit?
Old Sep 29, 2010 | 04:04 PM
zooguy's Avatar
Default will these 17x9 fit?
i want to know if these will fit?
http://www.wheelsnext.com/wheels-rim...yperblack.html
i dont know how backspacing really works but could some one tell me?
Old Sep 29, 2010 | 05:09 PM
IROCSS's Avatar
At the top of there page is a vehicle input to see if they fit. If for the 95 firebird it says they will not.
Old Sep 29, 2010 | 09:04 PM
9WhiteCamaro9's Avatar
hey op i helped ya out i did the search thing for ya and according to what the website says yeah they will fit
Old Sep 29, 2010 | 09:24 PM
Deviant LS1's Avatar
Here's the sticky at the top of the forum.
https://ls1tech.com/forums/wheels-ti...must-read.html
You would need the 5x120 bolt pattern to work. Ours are 5x4.5 or 5x120.65 mm. Some people say you can interchange 5x120 and 5x120.65 while others strongly oppose it. I'll let you make your own decision. The wheels you posted only offer a +25 offset for a 5x120 bolt pattern. That will push the wheel too far out and it will stick out past the fenders.
Old Sep 29, 2010 | 10:07 PM
^ ok OP id go with what he said cause i didnt read that much into the wheels other than the vehicle search part and they came up under '95 T/A to Firebird
Old Sep 29, 2010 | 11:32 PM
zooguy's Avatar
what would the 42 offset do ? will they tuck better?
Old Sep 30, 2010 | 09:18 AM
Xsta Z 28's Avatar
Exclamation
42 mm would be fine . . anything between 35 mm to 50 mm in a 9" width will fit.
Old Sep 30, 2010 | 10:31 AM
That 17x9 +42 offset in those wheels have the wrong bolt patterns for our cars.
Old Sep 30, 2010 | 04:21 PM
leadfoot4's Avatar
I'll say this...It is a sharp looking wheel, but I was never big on dual bolt pattern wheels. Not a lot of "beef" around the lug circle, assuming, of course, that it would fit a 4th gen....
