28x10.5 Slicks,with stock wheel wells?
![Post](https://ls1tech.com/forums/images/icons/icon1.gif)
Just wondering if everybody running 28x10.5 slicks,have factory wheel wells. Or have you done some mods and opened them up? Im just looking at mine on the car, and clearance is about a half inch front and back.What about the tire rise,when heating at the track? Any advice on what everybody does about this, would be helpful.
Mine fit fine once I got adj lca's so the tire is right in the middle of the wheel well. Other then that they might take some work with a BFH depending on your rim and what springs you are running
Currently I'm running 17x11"(7.75 b/s) rim with 315x35x17 M/T's on rear and stock in front but I wanna do 15"s all around but I don't know if the 28" Or the 27.8" will fit cuz I had measured from ground to top wheel well and it's 28 &1/8" with out the rolling of the well but I really wanna do the 28" so plz so tell me if it can be done- thank you
Myself my rear is narrowed 2.5 on each side with a 5.5 backspaced wheel so pulles the wheel in about a 1/2 inch. I had to BFH the front area of the wheel well and I cut out alot of the metal inside where the bumpstop was and adjustable lower control arms are a must to center the rear. have about a inch in front and rear.
