Race Star rims! Post pics!
#450
Is there anyone running the Darkstars in a 17x7 15x10 setup? Also, for those running a 15x10, are you running them in a 7 1/2 back spacing, and if so, do they fit without having to grind the calipers?
Also, will I have ABS issues with running a 17/15 combo? Is there a specific size tire I would need to run in the front and rear in order not to have ABS issues?
#451
You do have to grind a little on the fins of the rear calipers with the 15x10, took me ab 5 mins total. With a 26'' tire up front and a 28 out back my ABS light comes on, I think my buddy has roughly a 27'' tall front with 28 rears and doesn't have that problem.
#454
Is ANYONE running the 17x7 4.5 bs on the fronts? I think the 17x7 4.5 bs and 15x10 7.5 bs would look really killer.
If I run a 275/50/15 tire on the back, what size 235 front tire would I need to run in order to for the tire heights to be the same so that I don't have ABS issues? What about a 325/50/15? I like the idea of having a wider tire in the rear. From what I've seen the options are as follows:
235/60/17
235/55/17
235/50/17
Any of these work with a 275/50/15 or the 325/50/15?
235/60/17
235/55/17
235/50/17
#455
anyone have and pics with a full set of 17x9.5 all the way around?
also will 17x9.5 with a 44 mm offset work on 02 z28 with out and issues? do not what to BFH my car.
