How wide are these wheels? 18" Z06 from TomzWheels
Hey guys, I need to know the exact wheel width and offset for these wheels, but since TomzWheels is not around anymore, I need your insight! The reason I need to know the exact wheel width/offset is because I am ordering a set of 3piece and the fitment was done based off my current wheels. Here are some pictures below of the front and rear. The front tires are 275/35/18 and the rear are 295/35/18.
I will try to measure them tonight, but I know its hard to measure width since the tire is mounted.
thanks!
thanks!
I just measured the wheels from outer edge to outer edge and got these dimensions
Front: 10.5"
Rear:11.5"
I know the wheel width is measured from where the tire bead sits to the other side. Would that make an inch difference though?
The offsets I measured, which I believe are pretty dead on were:
58mm for the rear and 56mm for the front.
So overall would
rear: 10.5" with 58mm offset
front: 9.5" with 56mm offset
be correct as the wheels were advertised?
Front: 10.5"
Rear:11.5"
So overall would
thanks!
