Pics of my deep dish tt2's w/ toyo 345/40/17(added pics)
#61
Running 315/35/17 Mickey Thompson. Look ing for wider n taller tire. Running 4.10 gears. I see u running deep dish TT2. Im guessing Ur back spacing is different from my zr1. Read on a local forum a guy is running this tire with no spacers n a lot of BFH on a O.E wheel deep dish ZR1.
#62
#64
Ya I'll add some right now
Yes since my 9" is narrowed the BS is different.
#68
man thats a serious tire. i have a set of these in 315s waiting to go on eventually.
only thing is, i see no point running a 345 on an 11'' rim, cause your not getting full contact of the tire on the ground. but looks good anyways.
what psi are you running in them?
#70
Thanks everyone for your compliments!!
Thanks, I'm running them @ about 30psi. As far as the 345 on the 11" rim it's true not getting full tire to the ground. But I love the way it looks and it's my starting point. Next in line will be mini tub and getting either these wheels widened or some new ones in a 12"-13" wheel.
Thanks and you won't be disappointed with your 9" choice I promise!!
#76
Depends on a few factors; Width of axle, width of tires/wheels, how aggressive the mini-tub was, whether you have a Carmaro or Fire Bird and where you want the tires/wheels sitting in comparison to to body.
I've got rear wheels that are 18X13 with a 6.625" backspace that I think fit on my car perfectly. However, just because they fit on my car doesn't mean that they'll fit on your car perfectly. It's a good starting point if you have a similar setup, but you'll have to break out the tape measure to be sure.
