Anyone using 17" weld RT-S as front runners?
Old 01-13-2011, 04:46 PM
wheelczar's Avatar
Default RT-S Front
Originally Posted by 1ta2nv2000
4 piston brembo (04-07 CTS-V)
C6 Z06 Rotor
2000 Trans am
Hope that helps.
Sorry for the delay in getting back to you.
Your brake set up will require going to the 18 inch High Pad RT-S. This wheel has the most caliper clearance and will bolt up with no mods or brake caliper grinding. I was hoping to tell you 17 inch but it looks like a 14 inc rotor on there, so 18's will work.
Hope this helps you.
Old 01-30-2011, 04:46 PM
ls1muscle's Avatar
Originally Posted by wheelczar
Yes they will. Order medium pad height for caliper clearance.
Direct bolt on, no mods no grinding. SWEET!!
My 15x10's required slight grinding on the calipers to fit without scraping.
Old 01-30-2011, 04:55 PM
YURVIEW's Avatar
^^^ o well. No one wants to buy my billets, so guess I won't find out if they fit.
Old 01-30-2011, 07:05 PM
Camaro396's Avatar
We've seen a few cars that need a very slight grinding to keep them from interfearing with the calipar. So little that you could do it with a hand file, and the times I've seen this is less than I can count on one hand.
Old 02-01-2011, 10:37 AM
YURVIEW's Avatar
can anyone tell me the weights of the 15x3 and 15x10s??? Ive been waiting a month to get approved on the weld site forum, with no luck..... ???
Old 02-01-2011, 10:49 AM
wheelczar's Avatar
Thumbs up Weld RT-S Wheel Weights
The 15x3.5 RT-S weighs 10.35 lbs
The 15x10 RT-S weighs 15.10 lbs.
Quick Reply: Anyone using 17" weld RT-S as front runners?
