Polishing WS6 Wheels
Old Jan 8, 2011 | 04:38 PM
White94Bird's Avatar
Default Polishing WS6 Wheels
i have already stripped the clear coat off and am in the process of polishing but I can't get the chrome shine like I want..
pics..
polished left, stripped only right
polishing equipment
Old Jan 8, 2011 | 04:39 PM
the stripped ones look like chrome in person..
Old Jan 8, 2011 | 06:30 PM
wysemunky's Avatar
I bought one of those powerballs and the powermetal polish and, I could never get the shine I wanted. I had MUCH better results just using the normal mothers mag and aluminum polish with a lot of elbow grease and a clean soft cloth.
Old Jan 8, 2011 | 06:52 PM
RedHotG8's Avatar
You might have to do some sanding first with very fine sandpaper if there's any imperfections in the surface, then use a cloth buffing wheel and jeweler's rouge to get them to shine. They have large buffing wheels to use with a hand drill and small ones that fit a dremel for getting in the corners.
Old Jan 8, 2011 | 07:39 PM
J-Train's Avatar
Yes, I would go for the wetsanding first, finish with like 2000K grit, then I would go with jsut the regular mothers a few time snad finsish them off with the mothers "Billet" polish, its much better than the regular mothers, its like 9$ for jsut a small jar though, but it will let you get all the fine scrathes and swirls out.
Old Jan 8, 2011 | 08:15 PM
I already handed them with 1000, 1500, and 2000
Old Jan 8, 2011 | 09:07 PM
67goatman455's Avatar
once you sand them its a PITA to bring them back. i have 2 stripped wheels that look like chrome, and 2 that look a bit better than your sanded ones. I think im going to try the aluminum polishing wheels that you would get from eastwood.
Old Jan 9, 2011 | 08:44 AM
I'm going to try a faster spinning wheel and more agressive pad, hope it works..
Old Jan 9, 2011 | 10:49 AM
Alex41's Avatar
When it comes to polishing aluminum you have to do it by hand and go back and forth instead of circular polishing. The idea is to lessen the look of scratches and by going one direction it fools the eye.
Old Jan 9, 2011 | 02:01 PM
sjsingle1's Avatar
polish.....polish..and polish some more
Old Jan 11, 2011 | 08:12 AM
DopdBrd's Avatar
Just wondering, what did you use to strip them? I have a set I bought to put on my car and on some places the clear coat is stained so I was thinking about just stripping them down to metal and polishing them.
Old Jan 11, 2011 | 05:16 PM
HAte's Avatar
they need to be polished with a buffing wheel and ruge, coarse pad then fine, you would be surprised how the buffer will take scratches out when actually buffed correct
Old Jan 13, 2011 | 09:53 PM
HavATampa's Avatar
If the stripped ones looks like chrome, why are you polishing them and making it worse? I stripped mine a few years ago and was amazed how shiney they were without sanding them. You have to know what you are doing before breaking out the sandpaper on aluminum.
Old Jan 15, 2011 | 03:04 PM
There is still oxzdization on the wheels thats why im sanding them...
Old Jan 15, 2011 | 08:31 PM
SVTTHIS's Avatar
you need to sand them over and over again lastly with 12-1500grit to get all the marks out then use a super high speed buffer with rubbing and polishing compound and this stuff its called tapila or tipala something like that lol hope this helps mine always turned out good...
Old Jan 15, 2011 | 08:56 PM
DopeFedZ's Avatar
http://www.eastwood.com/ew-wheel-buffing-kit.html
That will take care of your problem. If you have a bench top buffer/grinder buy a 6" spiral sewn buff wheel from eastwood along with some tripoli buffing compound. Once you're done with that switch to a loose buff and some simichrome and they should look awesome. If you want to protect your hardworking from waterspots coat them in sharkhide which you can also get from eastwood.
Old Jan 16, 2011 | 09:19 AM
Sorry didn't see your post a first, I did 3 coats on each wheel jjust to make sure I got it all off.
Got it at walmart.
Old Jan 16, 2011 | 09:25 AM
I seem to have found a nice polishing system, buffing wheels that are used for buffing paint, cheap form harbor frieght, and my mothers polish then hit it with some blue magic
Old Jan 18, 2011 | 12:55 AM
JJsQwuik's Avatar
Would this work on my GM zr1 wheel, I mean stripping them so I can polish them???
Old Jan 18, 2011 | 02:08 AM
carlos64030's Avatar
No. It only works on WS6 wheels. Sowwyz.
