Where to find correct GM silver wheel paint? SS 10 Spokes
1 Post
Took a look down Autozone's paint aisle the other day looking for some paint for my 10 spokes. Closest I see is a dark silver metallic paint. The factory wheels were a light silver w/o metallic in the paint. Want the wheels to look stock if I can.
Another option if not, I ordered the silver metallic Manta stripes for my Camaro. Thinking of painting the wheels the same color which appears to be a lighter silver metallic paint than the spray cans at autozone.
Also anyone have a close up of the center caps? Previous owner painted them all silver. I believe they have the bowtie in the center with the dimples painted IIRC, just want confirmation.
its a hyper silver for sure. nothing your going to find at autozone. go to a local bodyshop and ask if they will help you out using there paint chip catalog. when you find a match ask for the paint code and your all set. and my stock ss center caps has SS no bowtie just fyi
1 Post
Well regardless of where you get it i would atleast go to a gm dealer and get them to pull that for ya. They would have to have the paint code your looking for as long as its stock
Yes there is a paint code for the wheels. Just sprayed a set not to long ago, Take the info to a paint supply house that can mix it for you, cost about 25.00 pint, this is a base coat and requires clear over.
Nason Ful-Base BC, General Motors Corp, year 1993, Brt silver sparkle with effect, code 9967, metallic/iridescent content > 5 grams/liter
Good luck, Gary
Good luck, Gary
1 Post
Good luck, Gary
Good luck, Gary
