Guys with ZO6 wheels, post pics please!
#46
#48
yeah man! youll like em.
what i did for the rear is took out the outside layer of the 'hump' for the spring. im going to trim it a little more, and possibly split the inner side and push it in and weld it together.
and...bfh on the front. they can fit...
#49
brennan---what size tires you running too? and those b&g springs i seen drop 1.4 inches...looks lower than that. you got the heater hose mod? i like how that sits.
also got any more pics of it? and possibly the bfh mod you did?
#53
I had to remove the hump too. I also need to weld that together. Front 295/35-18(my old rears from my 17/18 combo) ,rears 325/30-19. I'm running on b&g;(1.6). Also I cut 1 coil off the front, no heater hose mod. My front tires are to big, I need 285/30-18 to get the same profile and sidewall height. Sorry for rambling!
Brennen
Brennen
#57
Brennen
Brennen
im at stock ride hight now. but will probably be going with stranos soon.
and i need to find some 325/30s.
also, the last camaro posted with oem wheels is bad *** as well!
