Black T/A, Black 19" RPM 505's installed!
Snapped some pics at work today after I got the wheels on. RPM 505 19x9.5 on all four corners with 275/30/19 all around. Probably will run a bit bigger tire on the rear next go around since I still have some room height wise. 38mm offset. Also installed the UMI on car adjustable panhard bar that just happened to show up as I was getting ready to put the wheels on. Car is lowered on Strano springs and thanks Sam for the quick shipping on the panhard bar. I'm really happy with how everything looks.
![](http://i298.photobucket.com/albums/mm268/BlownGT99/Trans%20Am/rpm4.jpg)
![](http://i298.photobucket.com/albums/mm268/BlownGT99/Trans%20Am/rpm2.jpg)
![](http://i298.photobucket.com/albums/mm268/BlownGT99/Trans%20Am/rpm3.jpg)
That is awesome. I want those so bad for my WS6, just haven't pulled the trigger yet. I'd have a hard time explaining why I needed new wheels and tires, when the ones on the car are still new!!
What brand of tires are those? Was it a package deal or did you buy wheels and tires separate?
Here is an additional pic for those who might want to see up close clearance of fender gap with the Strano springs, and you can also see the tires and tread a little better. Although, the car is on a bit of a left bank where it is in the parking lot so the fender gaps may be a little bigger than if on perfectly flat ground, but none the less still plenty of room for 19's.
![](http://i298.photobucket.com/albums/mm268/BlownGT99/Trans%20Am/rpm5.jpg)
