15x10 Weld Prostars lugnuts?
Ok I am thinking about ordering the weld prostars for the rear of my z28. I was wondering if these lugnuts can be used on the stock studs? Thanks
http://www.summitracing.com/parts/MCG-63016/
Location: Your girl's back door giving her the long stroke while you're at work
That is the correct thread size but I would call Summit and make sure they will work with the Pro Stars. Also if you have extended studs you'll need open ended lug nuts
McGard lugs are the best.
