Which size nitto drag radials?
Old Apr 21, 2011 | 06:45 PM
litemup's Avatar
Default Which size nitto drag radials?
Im looking to get the Nitto NT 555R Drag radials. Yes I know others hook better but i drive this car 6000 miles or more in a year so I want something that lasts longer. I have 18" C6 wheels in the back that are 9.5 wide. I've heard the nittos run narrow so would the 305/35/18 nittos work or should i just stick with the 285/35/18?
Old Apr 21, 2011 | 08:16 PM
NovaCain383's Avatar
285/35/18 on the 9.5's. Ran them on multiple rides.
Old Apr 21, 2011 | 08:29 PM
TXZ28LS1's Avatar
I run 18x9.5 also and when i do get drag radials i plan on running 285/35/18 as well.
Old Apr 21, 2011 | 08:53 PM
Wildcobra's Avatar
Put the 305 35 18 Tires
Old Apr 26, 2011 | 02:10 PM
litemup's Avatar
what I am asking is has anyone ran the 305 nitto drag radials on 9.5 inch rims before? Will they fit?
Old Apr 26, 2011 | 03:52 PM
69z-28's Avatar
Run the 305 on the 9.5 wheel. I ran 315-35-17 555R's on my 17x9.5 wheels and they fit pretty good. You are correct the Nittos run quite a bit narrower than other brands. My photobucket account is messed up so i cant post the pic, but i've posted it in other threads, i took a picture of my 315-35-17 Nitto next to the same size BFG drag radial and the BFG had a good 1/2 to 3/4" on the Nitto. People will flame you and tell you not to do it but i know from experience, the 305 will fit better hands down, the 285 is gonna look way small.
Old Apr 26, 2011 | 07:16 PM
The 285 does not look small by far. If you run the 305 on a 9.5 the sidewall will be buldge out. Look in the sticky on this subject. Lot of good info there.
Old Apr 27, 2011 | 04:27 PM
Ghost99's Avatar
im wondering the same thing, thinking about 305/35/18 555r's for the rear but i have 9.5" wide c5 wheels..ive heard those tires work on 9.5s but it would be nice if anyone could post a pic with that setup?
Old Apr 27, 2011 | 10:50 PM
69z-28's Avatar
in reference to the Nittos being smaller, check this out...
Here is a 315-35-17 Nitto on my old car, next to a BFG drag radial, also a 315-35-17...
And here is the same 315 Nitto before it was mounted, next to a 275-40-17...
Nittos DO run smaller. Will the 285 work, absolutely, but the 305 will as well and it will not make a difference... just comes down to opinion.
Old Apr 27, 2011 | 10:57 PM
Also notice in the picture how the sidewall is buldging. Useless in a drag radial with that small a sidewall. Just wasting money to run a bigger tire that will never work the way it was intended to work.
Old Apr 27, 2011 | 11:21 PM
69z-28's Avatar
yep, but personally i thought the slight bulge looked much better than a 275 Nitto with a lip sticking out past the sidewall. I'm not saying either is the right or wrong size, i'm just getting the point across that nittos run narrow. I would have never thought about running that BFG on a 9.5 wheel, but since the 275 Nitto was gonna be narrow and awkward (in my opinion at least), i went with the 315. The OP asked about this specifically so that's all I was getting at. On a 9.5, the 285 will work great, but so will the 305. Hope this helps Litemup...
Old Apr 28, 2011 | 06:48 AM
LS1RedZ's Avatar
I think the 305s would fit. A friend of mine ran 335s on a 10.5 wheel.
Old May 1, 2011 | 10:25 PM
litemup's Avatar
alright I think I am going to go with the 305's if everyone thinks those will hook better than the 285s.
Old May 1, 2011 | 11:38 PM
quick05's Avatar
285/40r18 nt05r
Old May 1, 2011 | 11:49 PM
allbaugh_04's Avatar
Do the 305s...I have had 315s on my 17x9.5s for almost 4 years now.
