Backspacing?????
Old May 6, 2011 | 07:20 PM
konceptracin's Avatar
Default Backspacing?????
I have a 2001 camaso SS and my new fab9 should be in soon...i want to get the rims orderd. the rearend is -3'' looking to do a 15x10 weld rt-s or pro star what would my backspacing need to be?
thanks
Old May 6, 2011 | 07:36 PM
alexus6798's Avatar
subscribed because I'm getting the same rear but want to run 17s. I think the BS needs to be 4.5 but don't quote me on that..
Old May 6, 2011 | 07:39 PM
CNTLSE 1's Avatar
yep B.S. will be 4.5
Old May 6, 2011 | 07:44 PM
4SFEDZ's Avatar
stock is 7.5, so take 3 off that and u get 4.5!
Old May 18, 2011 | 11:14 PM
Raptor_WS6's Avatar
thx!!! been looking for this
whats the stock backspacing for the front?
Old May 19, 2011 | 01:03 AM
uphigh07's Avatar
raptor how wide are the front rims, i can tell you just depends on width
Old May 19, 2011 | 01:18 AM
Raptor_WS6's Avatar
17x9 are stock rims...
my current rims are 18x9.5 with a +54mm offset but they are not flush with the fenders
Old May 19, 2011 | 02:41 AM
uphigh07's Avatar
well as far as 9.5 rims like the ttII's they have 7in back spacing i didnt no if you were trying to figure out for skinnys or what? what rim are you looking at buying that you need to know what backspacing to order that would probley help you out more
Old May 19, 2011 | 11:10 AM
Camaro396's Avatar
If you're ordering Weld RTS wheels, then 15x10 4.5" backspace is what you'll need out back, and 15x3.5 with 1.50" backspace is what you will need up front. Same with the rears with Prostars..however with Prostar fronts you can use a 1.75" backspace, but they won't fit over your OEM LS1 brakes, so you'll have to use a spacer, which will make them sit at about 1.5" anyways!
Old May 19, 2011 | 02:47 PM
Raptor_WS6's Avatar
in saving for weld rts
18x9.5
18x11
I know the rear offset
just need fronts. if I put 1"
adapter my current fronts
will have a +28m offset so
theoreticaly a 18x9.5 with a
+30 would be fine right
Old May 19, 2011 | 03:44 PM
GMRACER13's Avatar
9" rear narrowed 3" per side, Weld RT-S 15x10 with 5.5" backspacing and 295/55/15 M/T ET Street Drag Radials if you want the wheels to tuck under the fender.
Old May 27, 2011 | 06:07 PM
Raptor_WS6's Avatar
any help?
edit:
18x9.5 with a 37mm offset i think is what i need with med pad height
thx
