Front Spacer w/ C5 Brake Upgrade
I know the 5/16" spacer is the norm for F-bodies running the 15x3.5" Weld Front Runners. Does a different size spacer need to be run if you've upgraded your front brakes to the C5 rotors (12" diameter) from the stock F-body rotors (11" diameter)?
anyone feel free to correct me if i am wrong, but with C5 brakes you need to have at least 17" wheels, 15" front runners are a no go with C5 brakes. I have 17" TTII's on the front with c5 brakes and its a tight fit...... Assuming you are going with C5 Rotors and Calipers.....
I'm just trying to figure out if I need more of a spacer than 5/16".
