Fitting 10.5" wheels on the rear. Spacer?
I found brand new rims Z06 CHEAP! They are 65mm offset, would these come out too far on my car? I have a 4th gen axle.
Offset: 65mm
Backspacing: 8.54"
Bolt Pattern: 5-475
Rec. Tire Size: 285/35-19
Weight: 29.0lbs.
Finish: Light Grey Painted
Offset: 65mm
Backspacing: 8.54"
Bolt Pattern: 5-475
Weight: 29.0lbs.
Bump for a old thread
I am gonna get some 315 35 18 tires and some OE 10.5 wheels with 56mm offset and was wondering besides the BFH mod what else should I expect to do to make the set up fit flush ? I am on stock springs . So lift by the axle, do I need longer studs? Spacer? Cut the bump stops?? Lmk please !! My car has about 42k miles and only LCAs, and torque arm .so??
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I have 18 10.5 oe wheels with 305/40s on the back..I had to BFH and grind the bumpstop..I had a spacer on em but without longer studs I just didn't feel safe,so i took em off now the tires hit jus alittle bit with weight in the back and going over a big bump!! Lookin into gettin some hub centric wheel spacers to bring em out flush with the fender!!
I'm at stock height btw and I did recenter the rear...
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
