what bolt pattern do i have?
Old May 26, 2011 | 02:02 PM
adrynalinjunkie's Avatar
Default what bolt pattern do i have?
I have a 2001 Z-28 with stock front end are they 114.3mmx5 ?
The stock z-28 rims fit great but I swear my 5 x 4 3/4. Welds of my chevelle would have mounted up just fine if I had a spacer so they wouldn't hit the calipers. So do I have 114.3 or 4 3/4? Bolt pattern?
Old May 26, 2011 | 02:20 PM
blue99fbody's Avatar
5x4.75
Old May 26, 2011 | 04:18 PM
Thanks I remembered the wheels I ordered last year were metric 120.56mm x5 but if you convert that to inches it is the good old 4 3/4" gotta love that gm kept it the same.
Old May 28, 2011 | 07:57 PM
Fbodyjunkie06's Avatar
Yea all S-10's, Monte Carlo's, Camaro's, Caprice's, Chevelles, Nova's anything with a 10 bolt or 12 bolt rearend that is a GM product will have a 5x4.75" bolt pattern as long as it isn't a 3/4 ton truck with a 12 bolt and 10 bolt front end.
Old Jun 6, 2011 | 10:18 PM
808z28camaro's Avatar
Here is the break down of the bolt pattern you have on your fbody. Different manufacturers use diffent type of measurements
5x120.65
5x 4 3/4
5x4.75
FYI you can use 5x120 BMW fitments too with NO problems. I have before.
