making center caps fit better
I have some used ZR1s and the center caps fit, just not very tight and I dont want to lose them going down the road. FWIW they're not the kind with the retainer ring, just the plastic tabs around the perimeter and over time, they've become loose.
I'm thinking a drop or two of silicone may work unless anyone has a better suggestion?
TIA
TIA
something that will allow a tire shop to still take out the center cap to balance the wheel... i was just gona epoxy the ones on my eclipse then a shop pointed that out to me. duct tape!?
I used a rubber hose about 1" outside diameter. Cut it into halfs, thirds or quarters and see if you can shove those between the clips and the outer edge of each cap. If you want post a pic of what your workin with and ill draw it out. The wheels I modded are long gone
