OE wheels help
Thanks
The 11's will require in some cases some bump stop tweaking, massaging the fender well with a mini-sledge to create more clearance for when you do run into bumps, and at the very least and adjustable panhard rod so that you can get the rear close to perfectly centered. Like I mentioned in your other thread that the tubular adjustable control arms also free'd up some clearance.
the only thing you might have to do will be the BFH mod (big fn hammer) to hit a little on the inner fender to make sure the wheels/tires dont rub.
when i had 11s in the back i had to do a little big of it and had no issues.
this was in the camaro and i had to do the same thing on the ws6 when i had it.
only had to do it on one side on both cars.
