ccw 19x11 fitment
ccw 19x11 fitment
Does anyone know what i would need to fit a 19x11" ccw wheel with a 8.5" backspacing on the rear of a 2000 camaro. I can mount the rim with no tire and torque it on but the lip is touching the inner fender, will a spacer be enough or is it not even worth trying. Thanks for the help.
A 1.5 inch spacer should do the trick just fine. Im going to have to go with a 2". I have chrome c6z06 deep dish (19x10) and i cant even get a lug on. It also will depend on tire width. Id go with (and not over) recommended tread width.
If the sides differ significanlty, you'll need an adjustable panhard bar first, to get the rear axle centered perfectly, under the car. At that point, you can start talking about spacers, if necessary.
