Problem with 18x10.5 DD C5's
Old Jun 24, 2011 | 02:14 AM
02TransAm/Batmobile's Avatar
Default Problem with 18x10.5 DD C5's
While I was centering the wheel and rear with my new tire/wheels I noticed the tires rub on the inner part of the wheel well. I have it centered with an adjustable panhard bar and LCA's and I still get some rubbing. I haven't heard of people having issues with inner rubbing and heard of people swapping 315's with these wheels. I am running a 295 tire so what gives? Wrong offset?
Old Jun 24, 2011 | 07:47 AM
IronOutlaw's Avatar
Are you lowered? My 295/30/18s rubbed on my old lowered car. I had to BFH the inner fenderwells.
Old Jun 24, 2011 | 07:51 AM
Hugger Z's Avatar
I had to massage the inner fenders with a sledge hammer to clearance them for the tires. The 10.5 wheels are close to the right backspacing but still require some clearance to be added to prevent rubbing. I also had to trim my bumpstops as they hung up on the wheel when put on a hoist.
BIG_MIKE2005's Avatar
Yep, BFH mod that sucka & forget about it. Very typical issue for alot of tires over 275 width especially once you go up to a 18" wheel/tire combo.
Old Jun 24, 2011 | 12:31 PM
Revcore66's Avatar
You're running 295 40 series right? I'm assuming the 40 series has more tire bulge than the typical 35 series most people run. My 295 35's have only rubbed a couple times on extreme hard cornering with a passenger in the car.
Old Jun 24, 2011 | 01:15 PM
lethal bird's Avatar
Sounds like bfh mod is in your future.
Old Jun 24, 2011 | 08:03 PM
Hmm, I kinda don't like the idea of hacking at the inner wall with a hammer. My car is not a show queen but still. If I run spacers I'll have to upgrade the studs and those are a pain in the ***. Fudge, my car is a drain on my money.
Yea, its a 295/40R18. Fronts are 275/40R18, I know it's not the norm and a 35 profile is usually sought for but I like the way they fill in the wheel gap.
Old Jun 24, 2011 | 08:39 PM
Whats wrong with a little bfh. No one will ever see it unless there looking for it. Just saying
Old Jun 24, 2011 | 08:52 PM
DragonBlood's Avatar
BFH it, then use some undercoat chassis spray, and you will barely be able to tell.
Old Jun 24, 2011 | 08:55 PM
99canadahawk's Avatar
Haa ! I have the same problem with mine I just installed last week only mine are 295/35`s, they do rub a little I might run a thin spacer but it took very little hammering at all if any .
Old Jun 25, 2011 | 08:55 AM
Its really no big deal to hammer it man. Just take your time & make it all even & then like suggested respray the area with undercoat & it'll look factory. Only you will know you hammered it, no one will know just looking at it.
Also if you run just a 5/16 spacer you wont need studs & it will help the clearance. So you wont have to do as much BFH.
Old Jun 25, 2011 | 10:43 PM
pharmd's Avatar
Anyone have a suggestion on brand of spacer and where to buy?
Old Jun 25, 2011 | 11:11 PM
I heard even a small spacer like the 5/16's you mentioned is questionable for stock studs. If I'm going to run a spacer, I want to feel safe when I haul ***.
By Brett Foote | 2026-06-04 05:00:17
