Weldcraft wheels 1" be enuf for 315's?
Old 07-05-2011, 08:07 PM
Restricted User
z99ls1's Avatar
Default Weldcraft wheels 1" be enuf for 315's?
I was lookind to get my 17x9" c5 z06 wheels widend 1". So would a 10" rim be wide enuf for a nitto 315 tire?
Old 07-05-2011, 09:35 PM
Restricted User
z99ls1's Avatar
Nvm I guess my wheels are 9.5" and the nitto's require 10.5"! Now to decide if I want to spend $500 on getting my wheels widend!
Old 07-05-2011, 09:47 PM
NVR_SPDS's Avatar
Quit being a baby, and DO IT!!!
Stock:
Not so much!!
Mine are 11" wide with the Nitto Nt555 in 315/35-17. The 555s are about an inch wider than the 555Rs.
Old 07-05-2011, 10:14 PM
Restricted User
z99ls1's Avatar
I had the sumitomo 315's on these wheels and the wor like **** and didn't hook at all. Now I have the 275 dr's and it hooks alot better, but doesn't have the badass look. I would definately do it if I wasn't planing on buying a cam kit soon.
Old 07-06-2011, 02:45 AM
Restricted User
z99ls1's Avatar
I will probably do it when my 275's wear down and my cam kit has been installed for awhile. My 275's don't hook to bad from a 25-30 roll wich is impressive, but off the line they spin spin forever lol
Old 07-06-2011, 02:46 AM
Restricted User
z99ls1's Avatar
Stock:
Not so much!!
Btw your tires look really good on there man. Makes me miss the look of my 315's even more
Old 07-06-2011, 12:18 PM
toadzq8's Avatar
Nittos NT-05's on 10.5 Weldcraft widened 10 spokes, powder coated gun metal grey
Old 07-06-2011, 11:35 PM
Restricted User
z99ls1's Avatar
Sweet man, thanks for the pics. James over at weldcraft said it would be $215 a wheel for me so I think I will do it after the cam and when my 275's wear down.
Old 07-07-2011, 07:50 AM
toadzq8's Avatar
10.5 is the way to go with 315's most go 11" but the 1/2" makes a ton of diff when fitting them. I used a 1/2" spacer that I had a jig made to center the spacer and had it welded to the inside of the wheel so they would be hub centered . I just rolled the fender lip and didn't have to touch the inside of wheel well or bump stops. no issues perfect fit
Quick Reply: Weldcraft wheels 1" be enuf for 315's?
